Browse Forums Old Home Restoration / Renovation 1 Apr 23, 2020 10:41 pm Hi all, just wondering if it is possible to upgrade wall and ceiling insulation of an existing late 60s double brick house? If so, is it exorbitantly expensive? Re: Possible to retrofit insulation 2Apr 24, 2020 9:25 am Insulguard Cavity Shield https://insulguardinsulation.com.au/cavity-shield/ looks to be the easiest in terms of a retrofit. I was intending to get this done however COVID-19 got in the way. Re: Possible to retrofit insulation 3Apr 24, 2020 9:28 am Ah yes, I've heard of this. Although I think I read somewhere else on here that the air gap in the cavity is really important for insulation, and filling it creates a thermal bridge between the inside and outside, which can be counterintuitive? Have you heard anything about that? You can wash over existing pavers with 10% solution of water and hydrochloric acid, then wash off. The acid will provide for required bond key with new concrete. 1 36966 0 9827 In Qld it is a requirement that a builder must have a cost breakdown, for building a home to the same specification, with the same inclusions and the same finish. So ask… 1 4357 |
