Browse Forums Old Home Restoration / Renovation Re: Floor tiling 2Dec 08, 2014 8:56 pm Could be an expansion join or a cold join if the slab was poured in two lots. Either way you just need to use a rubberised adhesive to allow for any movement. [Edit: Advertising links removed by moderator] CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16566 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17528 Looking to tile the facade pillars rather than rendering. Builder is quoting 2500$ laying cost for upto 10msq. The 2 pillars come to be 16msq. So laying costs are 5000$… 0 7554 |
