Browse Forums Old Home Restoration / Renovation 1 Apr 15, 2025 11:05 pm Hi everyone, Dilemma going on. We are looking at buying an older house, one of the old commission/defence force homes, built in Ipswich QLD in about the 70's. So of course, there is fibro thought the house - ceiling, walls, inside and out. It appears to be in good condition. So not too worried there. The problem is - if we want to extend and add another 2 rooms out the back, we will need to remove the fibro. And if we are doing to do that, then we're looking at removing ALL the fibro in the house to put in the extra ceiling lights, move some doors, bascially fix all the things we can live with but would prefer not to. Cut and paste of the house plan attached. Any idea on how much it would cost to remove all the asbestos, and then how much to put back in the ceiling, walls, do weatherboard cladding around the house, put the lights in etc. It's pretty well a rebuild except the frame is already there. I had read somewhere that the frame is probably the most expensive bit. The extension can wait if need be but if we are just redoing over the same without big room changes, are the costs down because don't need a certifyer etc. Just the usual waterproofing/hot water system/gas certifications would be needed. Some guidance here would be wonderful, thanks. S. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Same here, Carissa I had almost the same problem at my place last year with a leaning gum, and honestly the slope made everything ten times harder. It’s definitely not… 8 23326 We do around 10 demolitions a year and we went through so many companies who all do this as their standard practice until we found 2 who are ethical and we now split the… 11 10944 Thank you for your response Simeon. I really appreciate your thoughts. Yes that makes sense. Thankfully my renovation is fairly straight forward since it involves the… 4 37836 |
