Browse Forums Old Home Restoration / Renovation 1 Jan 09, 2025 2:20 pm Hi, Advice on the best product to render internal brick walls that is also cost effective and DYI π House is 40 year old on slab with solid Castlemaine rock as the exterior and brick on the interior making walls 300mm thick overall. Looking at these products below. Any advice on product, prepping would be very much appreciated. Cheers Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: Rendering internal brick walls 2Jan 10, 2025 10:59 am ![]() Hi, Advice on the best product to render internal brick walls that is also cost effective and DYI π House is 40 year old on slab with solid Castlemaine rock as the exterior and brick on the interior making walls 300mm thick overall. Looking at these products below. Any advice on product, prepping would be very much appreciated. Cheers Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Hi mate. Are you talking the whole house? Any form of hard plastering isn't going to be a DIY type of job if you have never done it before. Hard plaster is very messy because it's a wet trade. The walls have to be wet down as you do the work. There are 2 coats that get applied. A "float" layer that is a mix of sand, cement and lime that is trowelled on at about 10mm. This is used to flatten and straighten the wall. All external corners have plaster beads applied before this float layer is applied. This layer leaves a sandy slightly textured finish. After the float coat then a "set" coat is applied. This is just a thin coat of plaster or gypsum that gives the smooth hard coat that can then be painted. The work is messy and wet therefore any floor coverings would need to be fully covered, but even then it would be a struggle to do this without it being part of a full reno. Usually the easier method is dry lining. That's where plasterboard sheets are stuck directly to the brick work and then flushed. It's a lot cleaner to do this as you don't need to wet down the walls during application. It's still not really a DIY project if you haven't done it before or aren't familiar with the process. Both methods add about 10mm to the existing walls so there are a number of issues that you need to consider. The cornice, architraves and skirtings plus any power points and light switches will all need to be considered as the walls will all be built out 10mm. The simplest and most DIY way of changing the look would be to just paint the brick. It would be time consuming as painting raked motor joints is fiddly but it's definitely the easiest and most DIY friendly option. Good luck Accessible Carpentry & Cabinets accessiblecarpentry@gmail.com accessiblecarpentry.com.au https://www.facebook.com/pages/Accessible-Carpentry-Cabinets/583314911709039 Re: Rendering internal brick walls 3Jan 10, 2025 11:34 am Thanks for the feedback. It is the internal brick work on the internal perimeter only. Apart from the rear wall of the house there is not a lot as there are ceiling to floor windows except in the toilet and laundry. I donβt want plaster sheets, which is why I wish to apply render or bag. π We're trying to decide on interior colours for a new build we have surfmist window frames and spotted gum floors throughout the house I'm trying to picture how Casper… 0 20090 We used pro clima walls and roof. It's a high quality product (good vapour permeability and water resistance) and can withstand UV for a long period of time. Pro clima's… 10 36495 If you don't prefer to use nails/screws, you can rely on polyurethane based construction adhesive, something like Loctite PL Premium. This method is only effective if the… 6 22567 ![]() |
