Browse Forums Old Home Restoration / Renovation Make sure you have the required soil bearing capacity at the shallow founding depth and the strip footings are designed for the expected loads over (including the wind and… 1 8884 Generally you don’t need supporting piers/blocks under garage/non-habitable floating GROUND slab (That has no load bearing structures over) if it has good soil bearing… 2 8276 Just about completed a renovation project and hit a small issue that we didn’t see We have laminate floors now where we had tiles before (turned out it was actually 2… 0 13376 |
