Browse Forums Old Home Restoration / Renovation 1 Jun 11, 2023 1:49 pm Hi all, when replacing a kitchen and floor, do you install the kitchen on the subfloor then put your floor in (I’m doing engineered timber boards)? And accept that the bench will be a bit lower? Or flooring first? Or on the subfloor and build up the bottom of the benches a bit? Sorry if it’s a silly question! Cheers Re: Kitchen floors 2Jun 13, 2023 6:04 pm kitchen first sitting on stable floor then flooring then kickboard over the engineered floor. The height is up to you, use whichever feet you want to suit your height, if you are tall you might want over 900 slightly. if you are short you might prefer a bit below. Re: Kitchen floors 3Jun 13, 2023 7:59 pm Pulse kitchen first sitting on stable floor then flooring then kickboard over the engineered floor. The height is up to you, use whichever feet you want to suit your height, if you are tall you might want over 900 slightly. if you are short you might prefer a bit below. Awesome, I can do that. Thanks mate. Old Home Restoration / Renovation To reduce noise transfer without compromising the aesthetic of your exposed I beams, consider filling the 100mm gap between the I beams and the floor above with dense,… 6 16460 Sorry, don't know costs, but there are a couple of very important principles you need to get right (and now) .... (1) never agree to any "upgrade" unless you first know… 5 16331 A Sabco spin mop, minimal moisture, not very regularly. I was told these hybrids are water resistant 🤷♀️ 2 18172 |
