Browse Forums Old Home Restoration / Renovation 1 Oct 23, 2020 8:39 am Hi all I have started to have water leakage into the basement after excavating and underpinning the house. From previous interactions in This forum, I learnt that the right way to address leak is from its source which is above and outside the basement. Front of the house has slope towards the house. I engaged a plumber, water proofer and landscaper as 3 pronged approach. But after spending quite a bit of money, sadly, the issue still exists. This is what they did. 1. The water used to make its way through the front porch. So they dig a trench all the way to the foundation (about 6 feet down), put pvc pimple with holes on top. Covered it with gravels. There are 2 pipes along the foundation. A strip drain as shown in the photo collects the water on the surface. This is connected to the storm water system and the water goes out. 2. Water proofed the front porch completely all the way to the footer. 3. Changed the landscape so that the slope gradients towards the strip drain. Surface is sloped so that water goes to the sides. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ What’s surprising is that after all these steps, when I water the lawn, the water just makes into the basement. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I am at loss for what to do next. Plumber and landscapers had a look amd they are surprised this hasn’t fixed the issue. I was planning to increase the height of the concrete wall to see if that stops water from coming in. Since the water is coming through the exposed soil, I thought that might help. The plumber advised against it as he thinks the water will still make it around the concrete. Plumber is suggesting drilling cores through concrete all the way outside. This will take the water inside. Then get the water out of the basement into storm water system. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ What do you guys think? Is there any other way of doing it? Re: Water leakage into basement 2Oct 23, 2020 9:25 am Hey JustanotherUser The drainage system needs to be at the lowest point of the basement behind the concrete plinth. Generally basements require certified approved Systems/Solutions. Contact a specialist contractor Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Water leakage into basement 3Oct 23, 2020 10:33 am StructuralBIMGuy Hey JustanotherUser The drainage system needs to be at the lowest point of the basement behind the concrete plinth. Generally basements require certified approved Systems/Solutions. Contact a specialist contractor Cheers Chris Thanks Chris. The drainage system is at the lowest point. It is right next to the concrete plinth at a depth of foundation. Plumber had exposed the foundation and laid the pipes next to it. He is a certified plumber who had several commercial projects. What do you think of his suggestion of drilling cores and getting water inside and then getting the water out through natural gradient? Are there any consultants who look at these issues and suggest how to fix? I don’t want to do anything until I am reasonably confident it fixes the issue. I had gotten a water detector with thermal cameras before doing the job but he pretty much said what the plumber had said. Thanks Re: Water leakage into basement 4Oct 25, 2020 7:58 am JustAnotherUser StructuralBIMGuy Hey JustanotherUser The drainage system needs to be at the lowest point of the basement behind the concrete plinth. Generally basements require certified approved Systems/Solutions. Contact a specialist contractor Cheers Chris Are there any consultants who look at these issues and suggest how to fix? I don’t want to do anything until I am reasonably confident it fixes the issue. Thanks Try searching basement waterproofing , Tanking Solutions Please also check with your local Council Building surveyor for guidance on Compliance, Alternate Engineered Solutions & Certification (CAC) OT, As you can see there are many Experts offering solutions, check CAC BTW, CAC is a process within CDC Building Cheers Chris Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Water leakage into basement 5May 15, 2022 6:51 pm Just wanted to give an update on the fix. Chris above was right. The plumber hadn’t gone deep enough. So the water used to make its way to the lowest point and make it into the basement. We had to redo the agi drain going about 10 feet deep. That solved the issue. Costed us quite a bit but it has been 2 years and issue is resolved. I agree with Althom but there also may be a problem with the terra cotta stormwater pipe discharging water in that areas as well. You can just see the top of the pipe at… 2 15824 DIY, Home Maintenance & Repair to do it properly you need to dig out the garden and waterproof the outside of the wall. There are some products you can put on the face of the bricks but the water is… 2 4728 Thanks for your advice. So far i have not noticed any issues with doors and windows. Builder advised they will organise drainers to inspect 2 weeks ago but no further… 7 19045 |
