Browse Forums Old Home Restoration / Renovation 1 Sep 24, 2013 7:07 pm Help! We have just purchased a house that has pressed metal walls and ceilings. We need to remove and re-use it but am finding it extremely difficult. Can anyone suggest the best method. I have tried 1. grinding the nail head (hard to not grind the tin as well) 2. Centre punch and drilling the head off the nail (drill still wanders and elongates hole) 3. Wedging /levering from behind (bends and damages the surface) Very little success with any of the above, Re: Removal of pressed tin 2Oct 09, 2013 5:40 pm There is no easy way to remove pressed metal. That is why there is a scarcity of pressed metal in good condition in salvage yards. Every way you try to remove it you end up damaging it. Sorry to disappoint you but there is no solution that I know of. DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 7315 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 7438 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10867 |
