Moving General discussion to lower down the page might help in getting threads posted in the correct forum. It is on the top of the table and by moving it down, it's not going to be the first thing you see.
move it into "other" I say.
Browse Forums Bugs & Suggestions 1 Oct 15, 2009 12:31 am Moving General discussion to lower down the page might help in getting threads posted in the correct forum. It is on the top of the table and by moving it down, it's not going to be the first thing you see. move it into "other" I say. Re: Move General discussion 2Oct 15, 2009 9:02 am actaully i just had a good idea.... Invert the forums so that "other' is on the top and people can see the intro and forum help first just an idea... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Move General discussion 3Dec 29, 2009 11:44 am bump this up the top as no other site admin have commented... Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Move General discussion 5Dec 29, 2009 4:09 pm SuH Agree with Fu, put the General Discussions into the OTHER area but leave it at the bottom otherwise people will still go to General first, I reckon. or just rename it General Building Discussion.. then people may get the point of the sub forum Kodiak Data Cabling onFaceBook Consult*, Design and Installation Data, TV, Home Theatre/ AV Cabling, Multi Room Audio, IP CCTV and Door Intercoms Ask for a Quote. *DIY DATA Cabling Is Ilegal Re: Move General discussion 7Jan 07, 2010 11:28 pm TRhanks guys, We will look at this when the new look forum arrives shortly! Matt Re: Move General discussion 8Jan 09, 2010 2:49 pm mattwalker TRhanks guys, We will look at this when the new look forum arrives shortly! Matt ...I didn't know.... Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com You should check your detail drawings, it may show downpipe within brick pier. 14 14285 I have a home gym at home. It weights 150KG including the weight stack. I'm a big boy, around 150KG myself. I was thinking about moving it up stairs to the second… 0 6408 3 6522 |
