Browse Forums Forum Search Re: forum search suggestion? 2Jan 24, 2011 11:52 pm Try searching the site through google when looking for a 3 letter term - that's what I do. For example, if searching for PGH I would type the following in the search field - +www.homeone.com.au +PGH If you select the first result listed it will give you all the occurrences of PGH on the homeone site. Re: forum search suggestion? 3May 18, 2011 5:57 pm You can also type site:https://forum.homeone.com.au PGH Re: forum search suggestion? 4May 20, 2011 1:48 am If you are really good at searching Homeone, there is a proper homeone google search bar made for us by a wonderful member. Use my name in the search to help find it because I posted in the thread. No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11576 I have a really long hallway which is 1100mm W x 11500mm L I would appreciate if anyone can give suggestions to light it up with Linear LED lights that goes from wall to… 0 8811 Thank for yes basically what to remove and what to add, where to place them 2 7327 |
