Browse Forums Photos, Videos & Avatars Re: The avatar image file size must be less than 15 KB 2Mar 20, 2008 10:17 pm Zonk,
Typically if you do a save as , you can select the quality level and that will reduce the colour ratio and picture size. What program are you using? i use Infranview and it has a resize/resample option as well. Some sample files are here if you want to take the easy way. http://forum.homeone.com.au/viewtopic.php?t=3937 Steve at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 18442 Mate, Appreciate your engagement here and interest in my posts. Thankyou! 14 5576 I agree and was one of my concerns re: gutter size. It may be a suck it and see item now as they have not fitted the appropriate size. with the tank overflow, I am… 4 2435 |
