Browse Forums Flooring & Floor Covering 1 Sep 29, 2008 10:16 am Re: How to convert Linear metre into metre square? 5Sep 29, 2008 2:50 pm 'chelle We have a hand-over date...15/10...but I won't hold my breath! http://people-in-glass-houses.blogspot.com/ Re: How to convert Linear metre into metre square? 10Sep 29, 2008 3:57 pm 'chelle We have a hand-over date...15/10...but I won't hold my breath! http://people-in-glass-houses.blogspot.com/ Re: How to convert Linear metre into metre square? 14Apr 01, 2009 11:06 pm It's simple. If you have 80 sq. meters, just divide it with the width of the board. Eg if your floorboards are 19cm = 0.19m wide, you will need 80/0.19 = 421 linear meters. They suggest to add at least 10% for cutoffs, so you will need 421 + 42.1 = around 463 linear meters. consider putting in wall WC instead of robe in the same bedroom, then it might be doable to hook up to the existing piping. 4 6634 No idea about the driveway question, but your price for a house that size including landscaping seems very good! 1 6174 I use Tramex moisture meter and it will tell me instantly if the wall is cement sheet or plaster or masonite but most people dont have the equipment. 5 7094 |
