Browse Forums Flooring & Floor Covering Re: Sagging timber structural beam. 3Feb 24, 2020 9:06 am Designer,Engineer (Civil,Const & Envir),Builder,Concrete & Masonry Contract.Struct Repairs Re: Sagging timber structural beam. 5Feb 25, 2020 1:21 pm Pulse If it is just that bearer it could be a localised load, bookcase or something else heavy causing the deflection. Technically council needs to be informed of structural renovations but this is well within the scope of a builder/carpenter and can all be done within engineered lvl span tables or AS1684 span tables. It doesn’t need an engineer as it is within the scope of AS1684. Thanks For your advice Pulse, looking at the span guide it appears that it is a bit long and a new column should do it. Hello everyone, After some suggestions and ideas about how to put a concrete path around the drop edge beam area on our new build. We are required to have a concrete path… 0 12871 The distance between my DEBs varies from 4.1m at the narrowest to 8.1m at the widest. 5 27305 |
