Browse Forums Flooring & Floor Covering 1 Sep 21, 2008 7:08 pm I have just gutted our laundry with the view of retiling walls and floors.
Our walls are plaster on double brick. When removing the old wall tiles, a fair bit of the mortar came off as well. My question is, how much of the old mortar do I remove around the walls? The plaster is crazed in several places, should I re-mortar this as well? Also, the netting underlay from the original floor tiles is still very well fixed to the floor. Is there any reason to strip this? Any help is much appreciated. Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on… 3 8417 I have an investment property and tenants moved out recently. However the Property manager noticed one of the floor tiles is broken and the kitchen Island countertop is… 0 12899 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16561 |
