Browse Forums Flooring & Floor Covering Re: Re leveling house ‘jack and pack’ 4Apr 04, 2019 9:36 pm aussieta 1st quote sounds more realistic but we dont know how many stumps need levelling without going under your house Thank you for your reply! I appreciate it. How can they accurately quote without going under the house then? It did actually shock me that neither company went under the house, the just waved a torch around from the trap door and came up with a figure... Re: Re leveling house ‘jack and pack’ 5Dec 16, 2019 11:32 pm Naez, have you done the jack and pack? I have just had mine done recently and have got a bit of experience to say it all depends on what is required. Doors jammed or crack bricks to be fixed? Re: Re leveling house ‘jack and pack’ 6Dec 17, 2019 5:54 am You could be treating symptom and not a cause. There is a reason why your house is out of level how do you know what it is? In a worst case scenario you could spend the money and your problem will return. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Scientists have used random matrix theory to demonstrate theoretically that the neutrino mass hierarchy can be explained mathematically. When a substance is fragmented… 21 20650 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10030 You’re on the right track, wire brush in a grinder then a zinc rich epoxy primer then a top coat of some sort, like a waterproofing membrane. Raising the concrete would… 1 7030 |
