Browse Forums Flooring & Floor Covering 1 Mar 04, 2019 11:11 pm Hi all, I recently moved into a brand new apartment with engineered wood floating floors. They make strange clicking / cracking noises in some areas. Contractor is saying it is due to excessive humidity after installation which has caused them to shift, and that floating floors are always a bit noisy. Is this true? Or can I legitimately expect the floors not to make noise? Any responses would be greatly appreciated. Re: Cracking Noises - Floating Floors 2Mar 05, 2019 12:55 am I find the below article quite useful. 99 out of 100 it is NOT a properly installed flooring (expansion gaps are not adequate). https://www.woodfloorbusiness.com/insta ... loors.html As a damage prevention measure, consider reducing humidity in your apartment. Re: Cracking Noises - Floating Floors 3Mar 05, 2019 5:43 pm alexp79 I find the below article quite useful. 99 out of 100 it is NOT a properly installed flooring (expansion gaps are not adequate). https://www.woodfloorbusiness.com/insta ... loors.html As a damage prevention measure, consider reducing humidity in your apartment. Thank you Alex, that was interesting reading! I’ve watched some videos of similar noises and mine are not as bad, and so I’m not sure it’s going to qualify as a defect if I pursue it further. It was an off the plan purchase and the flooring contractor is insisting the floors have just moved due to humidity (no mention of faulty installation as one would expect) and not offering to replace or redo them. Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6781 Thanks, that's the motivation I needed to give it a try sooner rather than one day! 4 3472 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 1238 |
