Browse Forums Flooring & Floor Covering 1 Feb 08, 2019 4:30 pm Hi all, We have a split level, double story home with a maze of different flooring. The new extension (not done by us) has top of the range light timber look wide laminate boards. The middle section is very yellowed cypress pine and tile and the top in newer stained pine.. all the stairs are the old cypress. I want to unify the house and in the past I’d be loathe to cover timber BUT the laminate is quite nice and much lighter. Do I laminate over the pine or do I rip up the laminate and refinish and white wash the whole house? DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6580 I’m just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52851 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 10970 |
