Browse Forums Flooring & Floor Covering 1 Jan 11, 2019 3:17 pm Hi Guys Garage floor (car is housed in garage) was originally sealed then painted over, now it's coming off, have tried to gernie and repaint with no luck.....can you put an oil based sealer over the top to stop this from flaking? HELP! isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17413 6 11122 The best advice is for you to get a competent building consultant to guide you through your build 7 4647 |
