Browse Forums Flooring & Floor Covering 1 Oct 09, 2018 10:13 pm Hi, I like many here building a house for the very 1st time. Usually we preoccupied our self with designs , color selections etc. After my build has started I only realised that the 1st floor live load weight of my house only supports 152kg per m2. I assume unless you specify your builder to say you want 200kg per m2 , they will just do the Australian standard. This is what they call live load. ie. Including furniture , people etc. So in effect if 2 adult snuggled up on a nice antique timber single seater sofa. It would easily go past the 152kg. I can see the 152kg. per m2 can be easily surpassed in many situations. But I guess all is well or else there will be a lot of news about 1st floor crumbling.... Re: Floor loading - Do you think about it? 2Oct 10, 2018 6:43 am You will be fine. It’s AS standard. Even garage floor have a load rating of 250kg/m2 and your car won’t sink into earth. No. It's not original. Circa early to mid 90s would be my guess and maybe even as late as early 2000s 1 3664 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 11663 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 13351 |
