Browse Forums Flooring & Floor Covering 1 Oct 07, 2018 8:45 am Hi All, Longtime reader of this forum and first time poster. Im renovating an old california bungalow and due to variances in in existing floor levels and finishes i need to bring the floor levles up approx 20mm in some rooms. Iam planning on doing this by sheeting over the existing floorboards with 19mm plywood. Just a couple of questions: 1. Am i better to screw fix or nail fix and does this need to be through the boards to the joists? 2. Do i need to run the plywood at 90 degrees to the floorboards? 3. Do i need to provide glue between the two as well. Any advice is much appreciated. Hi, Currently building, we are on a sloping block so we have from floor level to the roof in axon cladding. Below floor level to the ground I want to put brick facings /… 0 4494 4 11221 1 19743 |
