Browse Forums Flooring & Floor Covering 1 Oct 01, 2018 2:20 pm deleted M Y C U S T O M C O R A L B R O N T E 43 ...............Kitchen! 16 Nov 2016 https://forum.homeone.com.au/viewtopic.php?f=31&t=79581 Re: Joins in carpet 2Oct 01, 2018 6:20 pm MrsJM So what is reasonable when it comes to joins in carpet? I’ve included some photos below of the joins in my home. We handed over in Dec 2016 however these haven’t worsened- this is how they have always looked. Cora Homes and their carpet installer think this is reasonable but I beg to differ- and if it is I would have assumed they should have considered having the joins in a less obvious location. Like all things Coral Homes, they don’t seem to have any pride in their finished work. I really appreciate your thoughts. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I don’t believe they should be that visible. We can see one in our master bedroom but none noticeable in our living areas. I think if it is laid properly it should be hard to notice them. Re: Joins in carpet 4Oct 02, 2018 8:13 am It’s a problem with homes with larger open plan spaces, but it is also very dependent on the carpet. It tends to be worse with plain finely cut carpets and less noticeable if the carpet is patterned and textured. 1 11004 1 15753 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6584 |
