Browse Forums Flooring & Floor Covering 1 Sep 16, 2018 3:27 pm Re: Tiler damaged balcony tile...how to fix? 3Sep 19, 2018 6:55 am StephanieHenty Start by placing a rag over the damaged tile and then shattering it with a hammer. Actually, you should start by scraping out the grout around the tile. This creates a gap between the tile you want to break up and the surrounding tiles so there is no bridge for a transfer of force that will unintentionally break the other tiles. Re: Tiler damaged balcony tile...how to fix? 4Sep 27, 2018 8:22 pm arcadelt StephanieHenty Start by placing a rag over the damaged tile and then shattering it with a hammer. Actually, you should start by scraping out the grout around the tile. This creates a gap between the tile you want to break up and the surrounding tiles so there is no bridge for a transfer of force that will unintentionally break the other tiles. You have responded to poor advice from a serial spammer. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. Tiler damaged balcony tile...how to fix? 5Sep 28, 2018 6:45 am SaveH2O You have responded to poor advice from a serial spammer. Yes, to improve the advice so the OP doesn’t just smash the tile with a hammer and ruin every tile around it in the process. Edit: that said, the one time poster probably hasn’t been back to read it anyway. Re: Tiler damaged balcony tile...how to fix? 6Sep 28, 2018 9:01 am arcadelt Yes, to improve the advice so the OP doesn’t just smash the tile with a hammer and ruin every tile around it in the process. Oops! My bad. This particular forum spammer has had a free ride on various threads for some time, probably because the reporting process is not prominent. I'll send an improvement suggestion to Homeone. For members reading this, each post has a row of three (very light) dots in the bottom right hand corner. Clicking on this will bring up another ((light coloured) box that includes Report Post. Clicking Report Post will bring up a more prominent box that allows the post to be reported and the reason why. Reporting forum spam early will result in earlier deletion and less repeat spam in other threads. There has been a lot of spam lately. Forum advertisers are identified by having an orange coloured member's name above their avatar and it is this revenue stream that offsets a large part of the expenses incurred in running the forum. 3in1 Supadiverta. Rainwater Harvesting Best Practice using syphonic drainage. Cleaner Neater Smarter Cheaper Supa Gutter Pumper. A low cost syphonic eaves gutter overflow solution. It's hard to comment as the photos area bit dark ( you might need a new 15 - just got one and wow ) Jokes aside, I can see one member that is cracked. I would find a… 2 2213 Regardless of wall hung toilet or floor pan toilet your feet will be right on drain, seems to me the waste should not be in that location given the design. Also are you… 6 7041 First time building 2 storey home in NSW. Below Current plan have separate balcony. But thinking to do a multipurpose lounge with balcony (kind of sunroom) in first floor… 0 4780 |
