Floating floorboards over SLATE!
I DON'T want to lift the slate up because I know if I do that, I'll damage the wooden floorboards underneath and I don't want to have to replace that as well.
Is there anything I can apply on top of the slate to make it level, and seal the cracks, before laying down floating floorboards or laminate???
Thanks, Alicia.
1
To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of…
23/04/2024
1
just pull up the slate. If you go over the top, your tiles would not have an even surface to be glued to. Im no tiler, but i can imagine a couple of things being an issue…
23/02/2024
1
I would probably render it and then paint it as per your other advice, or gyrpock over the top.
