Browse Forums Flooring & Floor Covering Re: Vinyl Plank Flooring Questions Answered 56Jan 29, 2019 9:23 am Bebbsy GaryE Hi Nellie, yes, I still keep an eye open here. The differences between Hybrid and vinyl planks are as follows: LVT (luxury vinyl planks) are glued to the floor and come in two varieties, 2mm to 3mm "Direct Stick" planks and 4.5mm to 5mm fibreglass reinforced "Loose Lay" planks. The loose lay name is a misnomer, as in Australia even these planks must be installed using a full spread of pressure sensitive adhesive, while direct stick planks require a hard set adhesive. Both types require a solid surface - concrete, tongue and groove timber, plywood or chipboard. They also require Masonite underlay if going over tongue and groove. Their main advantage is they are a component product, meaning individual planks can be removed and replaced, or areas can be renovated and have extra planks added on to the existing field. They are also cut tight to skirting boards and require no scotia or replacement skirtings. Hybrid flooring is a newer product (planks have been around since the 80's, hybrids since about 2010), and is gaining popularity fast. They have the same top surface as planks, with a PVC wear layer. They also have a non-timber composite backing, which eliminates the distortion and "Cupping" associated with other floating types of flooring. As they are not glued to the floor, the sub-floor may comprise of any type of surface you may have: ceramics, cork, terrazzo, whatever. Being a click together flooring, you cannot replace individual boards, and as they are PVC (and will expand and contract) they must have a 5mm gap around the walls, which is covered by a scotia trim, or skirtings must be replaced. Both products must be installed on a flat, even surface, and neither can be installed over any irregularities, regardless of what you may be told. I would definitely recommend you use the "One stop shop", as opposed to multiple parties. Accountability rests in one place, which means the guys doing the prep work will do it properly and any problems will see you dealing with one set of people with no finger pointing. I hope I have covered this properly, any further queries, please don't hesitate to ask. That’s very useful info and advice. 🤗 Can you recommend a hybrid floor or LVP which is very ‘authentic’ oak wood looking? I have been looking at a Proline hybrid floor in Stamford colour and may have to get a sample so I can see what it looks like in my own house. I don’t like the flooring which is obviously fake looking wood, but I don’t want the maintenance issues and high cost of an engineered wood floor. Hi Bebbsy My husband and I are seriously considering putting down hybrid flooring because like you would like a more natural look. Having said that I have learnt that there is a some terrible hybrid floors and not all hybrid floors are equal. That is, make sure you ask where their product is manufactured. I have learnt that those made in China are a lot cheaper and have more issues. Products from South Korea are far more superior but also come with a higher price. There are a few videos on line if you google this issue prepared by flooring specialists. So on that basis, shop around and research companies who make the flooring and then sell to the installers. The other thing I found is that many say that flooring can be put over the top of tiles etc. Be careful as ultimately the finish could be compromised subject to what your current floor is like. Ask to speak to the installer if you can rather than the salesperson as they will tell you what they find and what works best for your product. Good luck! Re: Vinyl Plank Flooring Questions Answered 57Jan 29, 2019 11:04 am NellieB Bebbsy GaryE Hi Nellie, yes, I still keep an eye open here. The differences between Hybrid and vinyl planks are as follows: LVT (luxury vinyl planks) are glued to the floor and come in two varieties, 2mm to 3mm "Direct Stick" planks and 4.5mm to 5mm fibreglass reinforced "Loose Lay" planks. The loose lay name is a misnomer, as in Australia even these planks must be installed using a full spread of pressure sensitive adhesive, while direct stick planks require a hard set adhesive. Both types require a solid surface - concrete, tongue and groove timber, plywood or chipboard. They also require Masonite underlay if going over tongue and groove. Their main advantage is they are a component product, meaning individual planks can be removed and replaced, or areas can be renovated and have extra planks added on to the existing field. They are also cut tight to skirting boards and require no scotia or replacement skirtings. Hybrid flooring is a newer product (planks have been around since the 80's, hybrids since about 2010), and is gaining popularity fast. They have the same top surface as planks, with a PVC wear layer. They also have a non-timber composite backing, which eliminates the distortion and "Cupping" associated with other floating types of flooring. As they are not glued to the floor, the sub-floor may comprise of any type of surface you may have: ceramics, cork, terrazzo, whatever. Being a click together flooring, you cannot replace individual boards, and as they are PVC (and will expand and contract) they must have a 5mm gap around the walls, which is covered by a scotia trim, or skirtings must be replaced. Both products must be installed on a flat, even surface, and neither can be installed over any irregularities, regardless of what you may be told. I would definitely recommend you use the "One stop shop", as opposed to multiple parties. Accountability rests in one place, which means the guys doing the prep work will do it properly and any problems will see you dealing with one set of people with no finger pointing. I hope I have covered this properly, any further queries, please don't hesitate to ask. That’s very useful info and advice. 🤗 Can you recommend a hybrid floor or LVP which is very ‘authentic’ oak wood looking? I have been looking at a Proline hybrid floor in Stamford colour and may have to get a sample so I can see what it looks like in my own house. I don’t like the flooring which is obviously fake looking wood, but I don’t want the maintenance issues and high cost of an engineered wood floor. Hi Bebbsy My husband and I are seriously considering putting down hybrid flooring because like you would like a more natural look. Having said that I have learnt that there is a some terrible hybrid floors and not all hybrid floors are equal. That is, make sure you ask where their product is manufactured. I have learnt that those made in China are a lot cheaper and have more issues. Products from South Korea are far more superior but also come with a higher price. There are a few videos on line if you google this issue prepared by flooring specialists. So on that basis, shop around and research companies who make the flooring and then sell to the installers. The other thing I found is that many say that flooring can be put over the top of tiles etc. Be careful as ultimately the finish could be compromised subject to what your current floor is like. Ask to speak to the installer if you can rather than the salesperson as they will tell you what they find and what works best for your product. Good luck! Hi NellieB I agree that not all hybrid floors are equal, but there are so many to choose from it is difficult to compare because a lot retailers sell different brands and say how great they are. I’ve also asked the question where the product is made, and most of the time the salesperson says they have no idea, or just gives me a brochure which does not provide that detail either. I have looked st a lot of different companies, and have narrowed down to two - hybrid flooring in the Proline Floors rigid plank range and also the Godfrey Hirst Napier range. (Godfrey Hirst has some negative comments on Product Review.) We are building a new house so don’t have the issue of laying over tiles etc. I’ve told the builder we need a good flat finish to our concrete floors so it is a level base for the flooring. How are you going with your own search, is there a product you prefer? Re: Vinyl Plank Flooring Questions Answered 58Jan 29, 2019 6:02 pm I'll toss in my two cents here, though as I stated earlier I don't install hybrid. NellieB is spot on about S.Korea vs China. Even large manufacturers have had issues with Chinese manufacturers, especially when it comes to sourcing plastics and other ingredients, with inferior materials being substituted for specified ones. S.Korean products are much better controlled, and it's interesting to note that S.Korea actually ranked second only to Germany for innovation in the past year, according to a recent survey. I can personally endorse Karndean products, they are the recognized market leader in quality, although that is reflected in their price tags. I would personally steer clear of any product which does not state it is manufactured in Korea; if they don't say, it's probably China. Also, Bebbsy, I would recommend you tell your builder your subfloor will need to meet the Australian standard for hybrid flooring, which is no more than a 3mm variation over 2m. If the installer is any good, he's going to run a 2m straight edge over the whole floor, and insist on filling and/or grinding anywhere that doesn't suit. You may not remember a good job, but you will never forget a bad one. Re: Vinyl Plank Flooring Questions Answered 59Jan 29, 2019 6:21 pm GaryE I'll toss in my two cents here, though as I stated earlier I don't install hybrid. NellieB is spot on about S.Korea vs China. Even large manufacturers have had issues with Chinese manufacturers, especially when it comes to sourcing plastics and other ingredients, with inferior materials being substituted for specified ones. S.Korean products are much better controlled, and it's interesting to note that S.Korea actually ranked second only to Germany for innovation in the past year, according to a recent survey. I can personally endorse Karndean products, they are the recognized market leader in quality, although that is reflected in their price tags. I would personally steer clear of any product which does not state it is manufactured in Korea; if they don't say, it's probably China. Also, Bebbsy, I would recommend you tell your builder your subfloor will need to meet the Australian standard for hybrid flooring, which is no more than a 3mm variation over 2m. If the installer is any good, he's going to run a 2m straight edge over the whole floor, and insist on filling and/or grinding anywhere that doesn't suit. Cheers GaryE I will take your advice about the subfloor. I got an email back today from Godfrey a Hirst confirming their hybrid flooring is made in a China. That has put me off I have to say. On the other hand Karndean has some very bad consumer reviews on a Product Review, so it seems there are issues no matter who you select. I actually found another hybrid floor today that I also like, and which I will research further. It’s a product made by Kenbrock and having seen it laid, was very impressed with the realistic appearance of the planks. Re: Vinyl Plank Flooring Questions Answered 60Jan 30, 2019 6:43 pm Bebbsy, Kenbrock are a good company, too. I worked with them for years when I was doing design floors and consultancy work. They have a strong commitment to customer service and I know from personal experience they care about product quality. Best of luck with your project, I hope it works out well. You may not remember a good job, but you will never forget a bad one. Hi l plan to install a self adhesive vinyl plank floor. l first need to attach masonite boards underlay to by plywood subfloor of my house. What size nails and how many… 0 8378 Levelling compound Ardit is the best but buy a bag of sand and make sand dam to protect your wood floor 2 15259 |
