Laminate Timber Floor Experiences???
I am reluctant with laminate - for some reason laminate just has a bad name in my head, although I actually have no experience with it! Can anyone who has laminate floors tell me how you have found them? Does furniture dent it? Do they scratch easily? Easy to look after?
Can anyone tell me how they compare to bamboo?
Thank you!
laminate is just a plastic with "printed" wood on it.
bamboos are good, but a bit on a hard side, oak is much softer.
We have decided on laminate again. With kids and pets it's the best option for us!
It's a wide board blackbutt laminate from Carpet Court. Good variances in boards and we think it looks good.
Good luck with what you decide.
what about engineered hardwood, e.g. oak? should be a good fit for your bedrooms.
Laminate is not plastic, you may have confused with something else.
Another thing to consider is scotia beading with laminate floors which also goes around kitchen bench. I recommend you find a display home with laminate flooring and take a look at that. Our builder will eliminate scotia beading if we leave the kitchen kickboards off and someone comes in later to install them and also go for wider skirting boards rather than standard, you can get rid of requiring beading. Good luck.
3
You have mandatory building inspections and privately engaged building inspections. The difference between the two comes down to inspecting the building so it's safe and…
6/07/2023
1
Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity.
5/09/2023
1
The most likely cause of your timber swelling (parquetry?) is either a plumbing leak or carelessly leaving water on floors after use or both. Without seeing, i am ignoring…
