Browse Forums Flooring & Floor Covering Re: Fixing timber battens to concrete 3Aug 23, 2017 2:19 am Yes, I am installing hardwood flooring on the battens. The level is within 3mm per 1.5m as recommended by flooring guides, so not packing. Are you able to specify the fasteners? In your photo are the items below battens for packing/levelling or for reducing moisture into timber flooring? Thx. Re: Fixing timber battens to concrete 6Sep 08, 2017 9:58 pm Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ We liquid nail the Battons Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Then liquid nail and nail down the floor boards (we use a nail gun we imported from American that drills down through the side of the board to the Batton. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ After sanding and sealing this is what they look like <!-- l --><a class="postlink-local" href="https://forum.homeone.com.au/viewtopic.php?t=62083">viewtopic.php?t=62083</a><!-- l --> Re: Fixing timber battens to concrete 8Sep 09, 2017 2:49 pm Yeah good question. We used it in our last house 20 years ago and never had an issue (although we've been out of there 15 years) <!-- l --><a class="postlink-local" href="https://forum.homeone.com.au/viewtopic.php?t=62083">viewtopic.php?t=62083</a><!-- l --> Re: Fixing timber battens to concrete 10Sep 13, 2017 1:04 pm alexp79 What is the advantage of placing hardwood on battens vs just glueing it directly to the concrete? Gives you the opportunity to level. Of course, if you just glue the batten to the concrete, that defeats that advantage. Re: Fixing timber battens to concrete 11Sep 13, 2017 7:39 pm alexp79 What is the advantage of placing hardwood on battens vs just glueing it directly to the concrete? It has the spring of traditional joist installation. arcadelt AKB We liquid nail the Battons I've always wondered what the effective life of an adhesive was? I'm not confident with the life of liquid nails. They crack as they age. However the T&G are nailed to battens it's unlikely to cause any issues if the battens separate from the concrete. I'll look into different shower heads and ask the plumber about some engineering and see what he says. Thanks 2 9551 Plumbers 'can be' plumbers, made all the worse by self certification which the building surveyor invariably accepts as proof of compliance! The good thing is that you know know. 3 4835 |
