Browse Forums Flooring & Floor Covering 1 Jul 16, 2017 8:04 am Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I bought these from masters closing down sale, there instructions are to lay the same as a timber floating floor with underlay and 10mm gap around edges to allow the floor to move, but it's pulling apart in the ends and a few edges, anyone else use these? I was going to pull up and remove underlay and lay without the 10mm gap,not sure if I should glue down Anyone have to do this before or have any ideas Thanks, that's the motivation I needed to give it a try sooner rather than one day! 4 3017 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 418 Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6164 |
