Browse Forums Flooring & Floor Covering 1 Aug 21, 2008 9:18 pm Hi,
We are building an extension to our existing Victorian house which has baltic pine floors. I am not too sure what type of floor to go for in the new part and what will look the best with the existing baltic. We have ruled out buying more baltic floor due to the cost and also because it is so soft. We have thought about bamboo in a similar colourto the baltic but I'm not too sure if this very new material will be too much of a contrast with the old. Timber is probably the other option but I am not sure which species will go the best with the baltic. Does anyone have any suggestions or advice on this?? Or do you think bamboo or another alternative may look good?? Thanks, Allison Re: What floor to go with baltic pine 2Aug 21, 2008 9:50 pm If you are looking at a hardwood floor rather than a softwood floor, I would go with a completely different complimenting colour rather than trying to use a similar tone. i.e. making a feature out of the different floors DIY, Home Maintenance & Repair Are you going to have the frame exposed or are you cladding it with something. Usually if you are making an exposed frame you would use solid legs around 100x100 or… 3 6767 Iām just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52976 Hi, as per the subject. Does anyone have any recommendations for the best value decking oil (Bunning is close to where I live) for a treated pine deck? Thanks 0 13119 |
