Browse Forums Flooring & Floor Covering Re: henley Flooring Carmelle Lux Q2 2Jun 20, 2017 7:29 pm we are doing externally as it is very expensive by henley. Hi, If you give a set of criteria as to what means 'good' to you, it'll give others prompts to respond. We considered Henley early on but there were two factors that… 1 12576 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6576 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16402 |
