Browse Forums Flooring & Floor Covering 1 Aug 22, 2017 9:02 pm Did anyone put floor boards on 1st level? If so how noisy is it when you are down stairs? I was thinking since the kids room is at the front of the house the noise would not be a factor as the living area is at the back of the house!!! Building Laguna 40 Re: Floor Boards up stairs 4Aug 22, 2017 9:53 pm Vet Thanks KushD not much on it Gave up the idea after I failed to find any house with floating boards to the upper floor around. To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 418 You will need to replace the entire stairs. Carpenter is the trade you're after. 1 4342 |
