Browse Forums Flooring & Floor Covering Re: Polished concrete floor ground too much? 2Apr 25, 2017 9:46 pm tracypk We can't tile over it as the non concrete areas have already been recessed into the slab Well, you could. Just get them to keep grinding another 12mm and then you can lay a 10mm tile. They make the room much easier to clean for one, reflect more light (if light colour tiles are used), and you dont end up with dust on the top edge of tiles (cause most… 3 9594 Hi everyone, Looking for some advise. We are about to build an above ground pool in our backyard. There is a private sewer line running under the pool at 1.6m… 0 11757 |
