Browse Forums Flooring & Floor Covering 1 Oct 03, 2016 7:30 am Dear all, I am sending to all of you big greetings from Moscow, RU, and have a very inquisitive question. I am going to do the flooring by self-alignment mix (I am not sure that this is correct name in English, sorry) at my home and I was very disappointed that it is impossible to by special beacon for precise leveling in Moscow. Noone sells those devices. If my explanation is not understandable, please see the picture. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ My question to all of you - how is this thing called in English correctly? I tried a few times to use dictionary and to assort the suitable translation but I cannot find anything. I want to search for it outside Russia. If you can recommend me how to buy it and where - I will be very thankful Re: Very specific question from other part of the world 3Oct 03, 2016 3:51 pm A laser level will do the trick and you can buy it on eBay and have it shipped to you. Foremost Building Expert in Australia,assisting with building problems/disputes, building stage inspections,pre-contract review advice for peace of mind 200 blogs http://www.buildingexpert.net.au/blog Re: Very specific question from other part of the world 4Oct 03, 2016 4:28 pm Yes, self leveling compound. The piece I showed to you is the special ranging mark for leveling. Although the compound is self leveling it is not able to level ideally itself if you pour it in one point of surface. You should rake the liquid compound initially using this device (ranging mark) that I inserted the picture. Can someone tell me how this ranging mark is called correctly? What to type in search field on eBay? Can you share a link with similar devices? Re: Very specific question from other part of the world 6Oct 06, 2016 7:04 pm http://banya-expert.com/poli/kak-ustano ... -pola.html i would call it a depth gauge, as to where to buy it the only links i can find are where you copied picture from Hi - thanks for your reply. Yes I think 'Ill go for whitish with very speckly bits rather than pure white something like this. PS was actually 2008 I built the… 2 11709 I recently went through a similar renovation and move scenario when updating our family home. We also swapped some rooms around and tackled a major… 2 10050 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9971 |
