Due to the fact that Marble and Travertine are of a porous nature, using the wrong adhesive and applying it wrong, can be detrimental.
Firstly, it is important to use White Marble fix, because if you use a grey adhesive, for instance, the colour will bleed through, staining the tile, which will discolour the tile.
It is also important to apply it to the tile by “buttering” both the tile, as well as the surface, to insure the tiles being laid in a solid bed of adhesive, to prevent weak points, therefore preventing cracking or breaking.
The picture below, clearly shows how the adhesive should NOT be applied, which caused this tile to break.
Please see previous post for " HOW TO PRE-SEAL NATURAL STONE TILES" here: viewtopic.php?f=53&t=82650
The picture shows how the adhesive should NOT be applied, which caused this tile to break.
And if you have any questions or good ideas for sealing of natural stone tiles or application of adhesive, please share them with us.
For Further information on natural stone tiles, please contact us.
Artmar Natural Stone Warehouse Pty Ltd Australia's Leading Stone Specialist
Artmar Natural Stone Warehouse Pty Ltd is an importer of natural stone from Turkey to around the globe with distribution centres in Australia and South Africa. We are proud to be the only Australian natural stone company which has manufacturing facilities in Turkey.
