Browse Forums Flooring & Floor Covering 1 Feb 21, 2016 9:05 am Does the floor tile thickness matter. We like two porcelain tiles (Belga Grey 450 x 450) is about 7mm thick, while the other (Bellingen white ash 600 x 600) is around 9mm. We intend putting one of these two tiles throughout our living areas, both ground floor concrete slab and first floor yellow tongue. Re: Floor Tile Thickness 2Feb 22, 2016 11:21 am obviously the thicker the better but the fact that you are going with porcelain makes for a higher degree of accuracy needed for the preparation. For this reason, just pick the tile you like and ensure it is being laid by an experienced qualified tiler and not an apprentice. Thickness of tile shouldn't need to come into the equation. Re: Floor Tile Thickness 3Feb 24, 2016 5:00 pm Thanks for your help guys, we have decided to run with the Bellingen White. We have a tiler in mind, he isn't very good with English but he does a lot of work via one of the big tile outlets and they have recommended him. Possibly both depending on the sizing. Idea of working from the centre is that you dont have a 20mm thin tile at one end and a 400mm at the other end. A quick search on… 3 8401 I have an investment property and tenants moved out recently. However the Property manager noticed one of the floor tiles is broken and the kitchen Island countertop is… 0 12884 CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16537 |
