Browse Forums Flooring & Floor Covering Re: Karndean Looselay Flooring 4Aug 08, 2015 8:49 am Karendean is an excellent product. We installed black and white 'marble' tiles with 'grout' strips and the fancy inlaid tile border strips in our kitchen 15 years ago. Most used room in the house. We had two dogs. Stood up incredibly well. Easy to install yourself too. Husband did it. A1 job/finish Re: Karndean Looselay Flooring 5Aug 09, 2015 9:58 am philsmith72 You could get it installed only for $15 m2 Wow Philsmith.....its that the Karndean loose lay or anther brand of loose lay? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Karndean Looselay Flooring 6Aug 09, 2015 9:59 am We/Carpet Court Nowra - charge $100 a sq mt installed and $72 supply only. One of my very favourite floorings by the way! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Karndean Looselay Flooring 8Aug 09, 2015 10:07 am OK..not loose lay. Yes that's a really cheap quote Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Karndean Looselay Flooring 9Aug 09, 2015 10:30 am Smales89 Hi guys, just wondering how much per sqm you have been quoted for supply and install of Karndean looselay planks? We've been quoted $98/sqm from Solomon's which seems a bit extreme. Thanks Just buy the product supply only and then you can get a carpenter or floor layer to install it, you can get Godphrey hurst Vinly plank which is a lot better quality than loose lay for $45m2, Re: Karndean Looselay Flooring 10Aug 09, 2015 10:32 am Michelle OK..not loose lay. Yes that's a really cheap quote Not loose lay,we have Godphrey hurst Vinly plank Re: Karndean Looselay Flooring 11Aug 13, 2015 12:23 pm Thanks everyone! Yes we were also considering just purchasing the planks and installing them ourselves but didn't know how easy this would be and if we would be able to achieve a professional looking finish. 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6212 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15924 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6469 |
