Browse Forums Flooring & Floor Covering 1 Jun 22, 2015 5:07 pm Hi all. Just wondering if anyone has used the pre finished solid timber floor boards in a new build. We are looking at these but are concerned about them getting scratched/ damaged while other tradies are still working in the house. Would like to leave them until last thing as we are doing the floors ourselves, not through the builder, but the kitchen needs to be installed on top of the floor so not really an option. Has anyone been in this situation with these type of boards? If so, how did you protect them during the rest of the build? Many thanks Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15924 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8324 interesting situation what happened after builder issued final invoice? did you list as defect or not does the building surveyor have any responsibility? ie. issuing… 13 46972 |
