Hi guys,
Can you please advise if Sydney Blue is different from Blue Gum????
Can't find any rating for Blue Gum but saw lots on Sydney Blue Gum.
Please help!!!
cheers,
Hannah
Browse Forums Flooring & Floor Covering Re: Blue Gum??? 3Jun 30, 2008 9:15 pm Yes and no, there are several types of Blue Gum.
However, all commercial blue gum (i.e. flooring, doors etc) is Sydney Blue Gum (Eucylyptus Saligna) Re: Blue Gum??? 4Jun 30, 2008 9:22 pm floorit It's the same thing.. ....most of the time. It is important to specify. Sydney Blue Gum (E. Saligna) is what is commonly used in flooring, and people normally just call it Blue Gum. http://www.colemantimberfloors.com.au/g ... ey/?cID=10 Tasmanian or Southern Blue Gum (E. Globuli) is very common as a plantation tree, is found in Tassie and Victoria south of the ranges but is not used domestically as much. It is also commonly called Blue Gum. http://www.colemantimberfloors.com.au/g ... ern/?cID=9 Geoff - Decophile. Iām just in the process of replacing 2 stud walls that have been severely damaged by termites and am planning to use h2 blue pine. I just wanted to if anyone can advise… 0 52856 |
