Browse Forums Flooring & Floor Covering 1 Dec 27, 2014 6:21 pm We have the option to put in our bamboo flooring before or after we install the kitchen. From what I have read people are pretty split on the internet about whether to put the floor down first (and under the cabinets) or to put it down second (and around cabinets). We are not using beading/quads around the rest of the house so how would that work in the kitchen if you lay it down second? Anyone want to put their two cents in on what should be done first given the choice? Thanks Re: Floating floor before or after kitchen installed? 3Dec 27, 2014 9:12 pm We put the floor down first. If nowhere else in your house has any beading why put it in the kitchen and make it appear different? Settlement 1/2/12 New Shed 23/3/12 Slab poured 27/3/12 Frame complete 4/5/12 Roof complete 1/6/12 LOCKUP 29/6/12 Our new build blog http://kareenhillsownerbuild.blogspot.com/ Re: Floating floor before or after kitchen installed? 4Dec 29, 2014 6:02 pm I prefer after, leave the kicks off the kitchen then you only have to deal with the sides and front for scotia. Why pay that extra in flooring if you don't have to? Better still, IF the flooring has to come up for some awful reason, how will you get it from beneath the cabinets? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: Floating floor before or after kitchen installed? 6Dec 29, 2014 6:54 pm Sorry, I forget not everyones knows building slang. Kicks are the "kick boards" of your kitchen. And no they can't be used as an alternative to beading. If you leave the kick boards off your kitchen after it is installed, the flooring guys can come in and lay the boards just under where the kicks will be. Therefore giving you a neat look around the kicks when put on. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Thanks, that's the motivation I needed to give it a try sooner rather than one day! 4 2982 Hey There. No problems re jumping in. My original question was "should I have waterproofed" the concrete slab before putting batons down. We have been told we should… 7 4313 The unit normally clips into a metal plate screwed to the wall, either plate is not flush, or unit not hooked in and could be hanging from the pipes partly, either might… 2 15767 |
