Browse Forums Flooring & Floor Covering 1 Oct 15, 2014 9:21 am Hi, We are in the process of selecting our solid timber flooring for our new build in south east Melbourne. We are looking at spotted gum or grey iron bark. We would like to know the labour cost per m2, timber cost per m2. any reputable company if you want to recommend?? Thanks Re: Solid Timber Floor cost estimate in Mel? 2Oct 15, 2014 7:54 pm Dusty will look after you http://www.clintfudgefloorsanding.com.au/ The biggest variables on cost are the cost of the timber and the substrate the floor is going on to. High grade flooring is up to $100 per sqm, installation around $50 and finishing maybe $30 for a new floor. Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15909 Hi, I'd like some advice on the best option please on the estimate options we've been provided from our builder. This is for the… 0 4066 If this is a custom build then I would expect the builder to set out the door frame closer to the wall to avoid the gap between architrave and the wall and or specify… 9 8306 |
