Browse Forums Flooring & Floor Covering Re: I work in flooring - do you have a flooring question? 702Aug 20, 2018 9:53 pm ![]() Leksie5000 and wes2k.....are you both still good to go? I don't want to reply to questions if you have moved on.... Thanks ![]() Yes if you have some thoughts on it, let me know. Thanks! Re: I work in flooring - do you have a flooring question? 703Aug 21, 2018 7:39 am ![]() Opinion on vinyl planks? Vinyl planks are great, make sure sure you look at good quality though. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 704Aug 21, 2018 7:25 pm ![]() Hi Michelle Comments below. I am seeking ideas to improve flooring in this apartment to make it suitable and comfortable for young children and also bring it up to date. 1. I used SmartStrand with deluxe underlay in my house build and will definitely go for that with carpet if I have carpet. It was worth every cent and stain resistant. 2. Kitchen area as marked on plan along with bathrooms have quite a plain 400 brown ceramic tile which I don’t really like. 3. Carpet needs replacing throughout. The open area and bedrooms are carpet. 4. Wondering if there is any suitable option to go over the tiles in the kitchen or I need to start again? Considering if to re carpet the kitchen dining or do the whole open area and kitchen in another floating option? If that’s an option? Or I could do something in the kitchen that will suit bathrooms but I’m not doing bathrooms for now. You can go over existing tiles with Karrndean looslay or Karndean Corlok then take it through to the other areas. You will however have a bit of a step. If your only doing the kitchen either of those floorings will do. If your doing all of the areas I would recommend taking up the tiles to get the floor surface the same height. 5. I am concerned if I don’t carpet the main area it won’t look as nice with floor transitions in such a small space. Any ideas? The house build was a hardwood floor and I know little about other options. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 705Aug 21, 2018 7:28 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 707Aug 22, 2018 7:30 am Look for Karndean, yes they go directly onto a slab. http://www.karndean.com/en-a u/floors/easy-fit-ranges/karndean-looselay-longboard Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 708Aug 29, 2018 4:22 pm Sadly I've been advised I need to go to the body corporate for vinyl planks as its considered a hard floor, and the next meeting is not until April 2019. For that reason I will need to replace carpet with carpet. Re: I work in flooring - do you have a flooring question? 710Aug 31, 2018 6:18 pm ![]() Sadly I've been advised I need to go to the body corporate for vinyl planks as its considered a hard floor, and the next meeting is not until April 2019. For that reason I will need to replace carpet with carpet. Body corporate... hmm. ![]() Make sure you get a good quality carpet, then you'll be happy. All will be good. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 711Aug 31, 2018 6:19 pm ![]() Does anyone getting really wild pricing differences when getting quotes? I got 3 quotes, one for $19k, $22k, and $27k for the same house. But are you getting quotes on the same products? If not, yes your quotes will be way out. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 712Aug 31, 2018 6:40 pm ![]() ![]() Does anyone getting really wild pricing differences when getting quotes? I got 3 quotes, one for $19k, $22k, and $27k for the same house. But are you getting quotes on the same products? If not, yes your quotes will be way out. Yes, it is a quote on a specific Karndean product with the same floor plan given to 3 different shops. Re: I work in flooring - do you have a flooring question? 713Aug 31, 2018 6:44 pm ![]() ![]() ![]() Does anyone getting really wild pricing differences when getting quotes? I got 3 quotes, one for $19k, $22k, and $27k for the same house. But are you getting quotes on the same products? If not, yes your quotes will be way out. Yes, it is a quote on a specific Karndean product with the same floor plan given to 3 different shops. So now you need to ask them all....what are they quoting for prep. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 715Nov 01, 2018 11:06 am I’m getting conflicting advice from different suppliers in regards to the Karndean Looselay planks. We are researching flooring for a new house build which has concrete slab on the lower floor, and chip board on the upper floor. One supplier has said we just need to ensure the chip board has been sanded and the Karndean Looselay will go straight down on top. Another supplier will only quote with the inclusion of Masonite going down first.... which of course adds to the cost. I had thought that one of the reasons for Karndean’s higher cost is because they don’t require as much floor prep as the cheaper brands? Any advise is greatly appreciated. Re: I work in flooring - do you have a flooring question? 717Nov 01, 2018 6:49 pm ![]() I’m getting conflicting advice from different suppliers in regards to the Karndean Looselay planks. We are researching flooring for a new house build which has concrete slab on the lower floor, and chip board on the upper floor. One supplier has said we just need to ensure the chip board has been sanded and the Karndean Looselay will go straight down on top. Another supplier will only quote with the inclusion of Masonite going down first.... which of course adds to the cost. I had thought that one of the reasons for Karndean’s higher cost is because they don’t require as much floor prep as the cheaper brands? Any advise is greatly appreciated. Hi gcnicho....they are both wrong, or supplier no/1 is not using the right glue. Karndean looselay are designed to be laid over all timber surfaces if they are fairly level and in good nick. They must be glued in with pressure sensitive glue. Some choose to hard set, but its not necessary. You do NOT need to sand the surface first, the backing on this system is by far more advanced than all the other's and yes, that's why they are more expensive. In the link below it tells you that hard board is necessary in some cases, that would be on a VERY un-level surface. I meant to email home my specs I got directly from Karndean.... I'll try and get that over the weekend for you. The problem here is since the looselay's came out installation has changed a few times which has left a few people confused. If you have any doubts at all give Karndean a call, they will help you. I hope this has helped ![]() http://www.karndean.com/en-au/commercia ... reparation Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 718Nov 01, 2018 6:52 pm Very nice, I bet your pleased with it!! ![]() Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 719Nov 01, 2018 6:58 pm And for all interested, I'll be using the Karndean tiles in all my wet areas of my reno Looselay Colorado. A concrete look vinyl tile. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 720Nov 17, 2018 8:17 pm Hi Michelle Any idea about coretec proplus tacked (clip system) could not find too much reviews about them . I have check kardean but quite negative reviews . Interested in views on this too, although I have already picked hybrid (didn't want tiles either) and haven't heard many peoples reviews on it. I end up going for… 1 1574 ![]() Hi there, I am in the process of planning a new build, and I really like the Prestige Oak 21m boards. I think the Dover Grey colour looks perfect for our house. My only… 0 316 There are domestic vinyls that have a pretty good cushion backing on them.These might be a better option.Marmoleum is a pretty thin and compressed product. 7 4962 |
