Browse Forums Flooring & Floor Covering Re: I work in flooring - do you have a flooring question? 561Aug 10, 2017 7:01 pm Bamboo is a good floor as long as its laid well with the correct expansion gaps. For ALL hard floors you should always use felt pads under all your furniture to prevent scratching as furniture is being moved. Choose a timber floor that is a hardwood, that will prevent dents with heavy furniture. I LOVE the Oaks, they are matt and in my opinion will look even better with a few dents and scratches as time goes by. https://www.quick-step.com.au/en-au/fin ... 05_qs_wood Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 562Aug 10, 2017 11:03 pm Michelle, What is your advice about using high quality vinyl floors vs tiles for kitchen, laundry and powder room areas? My main concern is that tile can become cold during winter and this will require underfloor heating when barefooted, while vinyl is generally warmer and also looks much cooler. Thanks in advance Re: I work in flooring - do you have a flooring question? 563Aug 11, 2017 8:51 am Good morning alexp79, I love vinyl...I may never use a tile again on flooring thanks to the great vinyls on the market at the moment! If you use a Karndean product they can be easily removed and replaced if damaged. http://www.karndean.com/en-au/floors/look/stone Karndean losslay Long boards Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 564Aug 12, 2017 4:56 pm Thanks, Michelle. What is the best way to combine vynil floors with the wall tiles colour wise? Also, skirting boards won't be needed, so walls can be tiled right from the floor surface? Can vynil be also used for a shower base? Re: I work in flooring - do you have a flooring question? 565Aug 13, 2017 4:28 pm Hi alexp79, Wall to floor colour, that will depend on your colour scheme. Correct, vinyl butts up against the skirting or wall tile. Neat. NO!! Vinyl can not go on the shower base. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 566Aug 22, 2017 7:57 pm OK, selections are done for my new flooring. Karndean looselay long boards - French Grey Oak and Tuftmaster Ritola - Virtue 009. I'm very happy with my selections, these are my most favourite flooring's I sell to my customers every day and now I get to have them in my own home. Millie approves....that's a thumbs up from the kitten! It helps that I work in flooring and have 10 years experience in the industry....Choices Flooring Nowra. If you are struggling with choosing the right flooring for your home, you can call me for a consultation. I'll help you select the right flooring for the right style and more importantly, for how you live. This consultation should only take an hour at the most. I'll post photos when I get started. ! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 567Sep 09, 2017 12:56 pm Hi Michelle, we are having Illusions Loose Lay Vinyl planks in our house. We are a little worried what these are like in comparison to Karndean? Have you had any experience with Illusions? Our First Home - Building with Valeco in Brookhaven Estate viewtopic.php?f=31&t=89162 Re: I work in flooring - do you have a flooring question? 568Sep 13, 2017 6:31 am Hi breebarter, I have heard off the Illusions, but have not seen them. As far as I know there is nothing on the market as good as the Karndean, but yes very close. As long as the planks are glued down you should be fine Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 569Sep 16, 2017 1:11 pm Hi Michelle, I've recently bought my first home and removed the 20+ year old carpet. I'm going to put down laminate on a very small budget. I have managed to pick the same one twice in two different stores - Preference Oakleaf in Aspen Oak. However I can't seem to find many reviews of this brand online, do you have any thoughts or experiences with Preference Oakleaf? Re: I work in flooring - do you have a flooring question? 570Sep 18, 2017 7:25 pm Hi myfavouritescar, the name rings a bell. I'll check with the boys tomorrow at work for you. How thick is the laminate 7 8 or 9 ml? Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 571Sep 20, 2017 6:19 am I had a look at the laminate yesterday.... its 12mm which is the best way to go. But we have not been able to sell the product so they took it off the shelves. Looked ok to me. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 572Sep 20, 2017 5:31 pm Michelle I had a look at the laminate yesterday.... its 12mm which is the best way to go. But we have not been able to sell the product so they took it off the shelves. Looked ok to me. Re: I work in flooring - do you have a flooring question? 573Sep 21, 2017 5:31 pm Thanks for your input Michelle! Do you know why it hasn't sold well? I've been able to price it out at $29/sqm through an online retailer. Re: I work in flooring - do you have a flooring question? 574Sep 21, 2017 6:22 pm No Idea, maybe because we have so many other products to look at as well? The colours are good. Price point maybe? Who knows.... If its a good price buy it:) Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 575Sep 21, 2017 6:35 pm Thanks! Being on such a tight budget has made its hard to just choose something and go with it. You've put my mind at ease. Re: I work in flooring - do you have a flooring question? 576Sep 21, 2017 6:53 pm Just remember NO steam mops... and put felt pads under everything!! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 577Oct 07, 2017 10:10 am Is Quikstep the best laminate out there? We have heard varying stories from different flooring places - some say it's the best, others say there are better out there, others say that there is no difference in brands. We are looking at putting laminate upstairs in 3 bedrooms and a living area, as well as on the stairs. We also want 12mm if possible with a waterproof version. Re: I work in flooring - do you have a flooring question? 579Oct 07, 2017 2:46 pm Adelaide Girl Is Quikstep the best laminate out there? We have heard varying stories from different flooring places - some say it's the best, others say there are better out there, others say that there is no difference in brands. We are looking at putting laminate upstairs in 3 bedrooms and a living area, as well as on the stairs. We also want 12mm if possible with a waterproof version. Hi there Adelaide Girl, I prefer Quickstep.... but that's just my opinion. 12mm is the best way to go with any floating floor, less drum when you walk on it with heals. Also, because you are looking to do it upstairs, upgrade your underlay so it helps to keep that drum down from underneath. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 580Oct 18, 2017 5:34 am Why floating floors buckle - worth a read, sorry...its long. 1. Water Damage Water damage can come from several different sources. If a dishwasher has broken and leaked water everywhere, obviously replacing the dishwasher will fix the issue. However, there are other reasons why there could be water damage to your flooring.
2. Floatation & Movement Restrictions Laminate flooring is a floating floor system. The seasons, moisture, and temperature (inside and out) play important role how your flooring will perform. Sufficient expansion gaps are essential. Here are some things to look for to make sure your floor has optimum movement space:
Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39996 Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3538 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10190 |
