Browse Forums Flooring & Floor Covering Re: I work in flooring - do you have a flooring question? 903Feb 16, 2022 7:24 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 904Feb 16, 2022 7:37 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 908Mar 22, 2022 12:46 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 911Apr 22, 2022 7:15 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 913Apr 23, 2022 11:16 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 917Apr 27, 2022 7:54 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 918Apr 27, 2022 8:01 pm Check out my new 2mm vinyl plank from Karndean recently installed in my laundry! Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 919May 10, 2022 11:41 am Hi Sorry to be late in on this, we have existing Kardean floorboards and we are about to start some renos and was wondering if anyone knew the best way to remove the glue from the back and then store the planks so we may re-use most of them?? Re: I work in flooring - do you have a flooring question? 920May 12, 2022 6:24 pm dmm12 Hi Sorry to be late in on this, we have existing Kardean floorboards and we are about to start some renos and was wondering if anyone knew the best way to remove the glue from the back and then store the planks so we may re-use most of them?? All I know is, we use a heat gun to soften the glue and lift the planks. I guess once you get them up you could try a scraper. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39751 Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3503 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10105 |
