Browse Forums Flooring & Floor Covering Re: I work in flooring - do you have a flooring question? 602Dec 04, 2017 1:21 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 604Dec 04, 2017 4:26 pm BuildingWashington 32 with W https://buildyourfirsthome.wordpress.com/ Contract: 26/11/2017 DA: 28/03/2018 Admin : 26/04/2018 Const: 11/05/2018 Slab: 16/05/2018 Re: I work in flooring - do you have a flooring question? 605Dec 04, 2017 6:22 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 606Dec 04, 2017 6:26 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 607Dec 04, 2017 7:56 pm BuildingWashington 32 with W https://buildyourfirsthome.wordpress.com/ Contract: 26/11/2017 DA: 28/03/2018 Admin : 26/04/2018 Const: 11/05/2018 Slab: 16/05/2018 Re: I work in flooring - do you have a flooring question? 609Dec 05, 2017 6:33 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 612Dec 05, 2017 8:25 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 615Dec 18, 2017 7:31 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 616Dec 18, 2017 7:33 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 617Dec 18, 2017 7:35 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 618Dec 18, 2017 7:44 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 619Dec 18, 2017 8:28 pm Michelle Hi Pramos, yes you can sand and polish those boards. To get rid of squeaky boards means to screw down the offenders. Make sure all the nails are well into the floor before sanding, you will rip the sanding pad otherwise. Thanks Michelle Re: I work in flooring - do you have a flooring question? 620Dec 27, 2017 12:57 pm Hi Michelle,
How will tassie oak floor boards come up after having tiles and a plaster sheet laid over the top in the kitchen. The house is from 1981. I am concerned that there will be a lot of nail holes and look bad. The alternative is to use a laminate in the living areas, kitchen and hall. This would be a shame to waste the oak floors and will cost more. What do you think? Here is a pic of the board, sheet and tile. http://i802.photobucket.com/albums/yy301/AlisonWinnall/IMG_4923_zpsgkaxvjq2.jpg Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 30563 Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 2818 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 6783 |
