Browse Forums Flooring & Floor Covering Re: I work in flooring - do you have a flooring question? 582Oct 19, 2017 5:32 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 584Oct 19, 2017 5:48 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 587Oct 30, 2017 5:33 am Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 589Nov 06, 2017 6:19 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 590Nov 16, 2017 5:31 am Good morning, below photos are using Choices Flooring's "Elements" vinyl planks. 2mm think, direct glued to the slab. Affordable tough and look great. The vinyl was laid into 6 units. Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 591Nov 21, 2017 6:20 pm Heads up... if you are keen on laminate flooring but are concerned about the water issues, check this lot out. Waterproof laminate and new colours from Quickstep just into the store this afternoon. No more worrying about those spills Questions? Let me know.... Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 593Nov 25, 2017 1:16 pm http://www.premiumfloors.com.au/brands/ ... -laminate/ Apparently.... you have quite a few hours to wipe up the water, unlike the non waterproof variety. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 594Dec 03, 2017 8:46 pm Hi Michelle, can you explain the difference between Super Tough Engineered Timber (Oak) and Engineered Timber (Oak) specifically to the top layer veneer thickness. I've seen some places sell either a floorboard where the top layer veneer is 1.5mm (15mm floorboard), 4mm (15mm floorboard), and 6mm (20mm floorboard). eg; this pic looks like 4-8mm of real hardwood Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ Re: I work in flooring - do you have a flooring question? 595Dec 04, 2017 5:30 am Good morning.... the thinker the top layer of timber the more often that floor can be sanded back. The basic top layer of 3 or 4 mm means you can only sand back once or twice in its life time. If you choose the right colour in the oaks I think they will look great with a few scratches and dents, like an old church floor. Remember....timber floor? Felt pads under all your furniture. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: I work in flooring - do you have a flooring question? 596Dec 04, 2017 7:42 am Hi, I haven't read the whole thread so you may have answered this already.... We are building a double story house and planning to do floating floors upstairs as well (ie no carpet), but concerned about noise. We are already putting in soundscreen insulation between the floors, but wondering what underlay you would recommend, and whether upgrading it would make a big difference?? For some strange reason the builder is not keen on upgrading it. Thanks Re: I work in flooring - do you have a flooring question? 597Dec 04, 2017 8:16 am Michelle Good morning.... the thinker the top layer of timber the more often that floor can be sanded back. The basic top layer of 3 or 4 mm means you can only sand back once or twice in its life time. If you choose the right colour in the oaks I think they will look great with a few scratches and dents, like an old church floor. Remember....timber floor? Felt pads under all your furniture. Hi Michelle, yes I know about the sanding, my question is why some are 1.5mm and some are 4mm and higher? Re: I work in flooring - do you have a flooring question? 600Dec 04, 2017 12:03 pm The thinner they are the cheaper they are. It comes back to the amount of timber Used. So it's all about pricing and materials. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Thanks mate. Yeah good points! Leaning towards Option 3 to get a bit extra space in the cabinets but not going too crazy high (and expensive). Would require a mini… 13 39716 Block of two storey townhouses requires painting on the roof. A brick parapet wall separates each unit and extends above the tiled roof. The parapet walls require sealing… 0 3502 I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one… 5 10098 |
