Browse Forums Flooring & Floor Covering Re: Painting Garage floor to stop spills absorbing 2May 13, 2014 6:06 pm There's the two-pac systems that paint and seal the floor and work well for driving your car on to it. I'm getting stories of $2000 for someone to come in and do it for you, to about $400 to buy the materials yourself. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Painting Garage floor to stop spills absorbing 3May 13, 2014 6:41 pm Sounds awesome, I'm trying to figure out if I just want a paint or to go the full solvent Epoxy.. these guys come highly recommended: https://www.dymark.com.au/categories/pr ... /epoxycoat Slooowwwwly getting a Manhatten 35 in Middleton Grange Re: Painting Garage floor to stop spills absorbing 4May 13, 2014 6:58 pm Oh Bpratt - do you have a link to the two-pac system (before I start googling) cheers AKB <!-- l --><a class="postlink-local" href="https://forum.homeone.com.au/viewtopic.php?t=62083">viewtopic.php?t=62083</a><!-- l --> Re: Painting Garage floor to stop spills absorbing 5May 13, 2014 7:15 pm I'm guessing if the intention is to drive your car on it every single day, then I'd say the normal paint would wear out fairly quickly, requiring regular repainting. Of course I'm sure the resin ones will eventually require re-applying, but the time between the two should be in the 'many years' category, versus 'a couple of years' category for normal floor paint. I hope we get more responses, and I'm keen to do something like this to my new home before we move in. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Painting Garage floor to stop spills absorbing 6May 13, 2014 7:17 pm AKB Oh Bpratt - do you have a link to the two-pac system (before I start googling) Here's the link for MR2's earlier post :- https://www.dymark.com.au/categories/pr ... /epoxycoat Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Painting Garage floor to stop spills absorbing 7May 13, 2014 7:23 pm yeahhh, I'm kinda keen for something that's a light gray, so I might ring them again... he also said that a heavy tool dropped on it is likely to crack it, not exactly what I'm after, more after something that will absorb the impact or just mush a bit without actually letting whatever oils might be around at the time to go through the coating and soak into the concrete Slooowwwwly getting a Manhatten 35 in Middleton Grange Re: Painting Garage floor to stop spills absorbing 8May 13, 2014 8:24 pm Too late to seal the floor after you've spilt oil and grease on the concrete. Owner Building at Jimboomba Woods in Logan City Qld. Blog : http://bandlnewhomebuild.blogspot.com H1 thread : viewtopic.php?f=38&t=68283 . Re: Painting Garage floor to stop spills absorbing 9May 13, 2014 9:16 pm well, it should soak into the concrete enough and be flexible enough that something hitting it will not allow whatever's on the other side of the epoxy to soak through the epoxy... or so I recon Slooowwwwly getting a Manhatten 35 in Middleton Grange Re: Painting Garage floor to stop spills absorbing 10May 30, 2014 6:15 pm My motor mechanic, who specialises in servicing European cars, has a workshop you could eat you dinner off. The concrete floor has been sealed/painted with epoxy/solvent based paint, however he covers his workshop floor with second hand salvaged carpet (which he gets for nil $). When I last had my car serviced he had white shag pile carpet ion the floor. He said the white carpet made in easier to find dropped nuts/washers etc & they did not roll away. When the carpet is dirty he throws it away & replaces it with more salvaged carpet. He works in rented premises so I suppose he does not want to have an oil stained floor at end of lease. Re: Painting Garage floor to stop spills absorbing 11May 30, 2014 8:07 pm Bunnings has a range of those epoxy coat kits, the one we have here was black in colour and came with with flakes to throw over it. Works quite well actually spills wipe up easily. Re: Painting Garage floor to stop spills absorbing 12Jun 01, 2014 9:11 am onggie Bunnings has a range of those epoxy coat kits yes, we bought the Hymark kit for $200, has worked a treat, on a 6mx7m garage I even had some left over, looks great, shame the roller I used was not fantastic and has left a few marks on it, still we will sand it back a little and do another coat as my partner is not happy with the slate colour (haha) Slooowwwwly getting a Manhatten 35 in Middleton Grange bec of more thickness and underlay i prefer laminate. also my builder covers laminate only. 2 14222 Hi Wokka, I would have to agree re "I would be taking this opportunity to replace your subfloor in the sections that… 2 11027 Thanks mate, is there a standard off the shelf type breathable product I can apply DIY? Thanks 2 17401 |
