Browse Forums Flooring & Floor Covering 1 May 18, 2008 5:08 pm Hi,
I just saw a bamboo flooring in natural shade and its fantastic. So, I decided to search for a bamboo flooring supplier.Ended up with Bamboo and Timber Select in Melbourne. They're currently doing also the click method as well as the glue method for solid bamboo now. They admitted having problems with their 9mm thick solid strand woven bamboo on the click method. Problems encountered, they say, are breakage and splitting. They said this was corrected by making it 14mm thick. Anybody here that has experience with bamboo flooring? I'll have concrete slabs on waffle rafting as builder say there's a high moisture content in my land, Land is class P. Will the moisture content of say, 30%, affect the type of flooring? Hope to be guided!!! cheers, Hannah 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6174 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 15886 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6454 |
