Browse Forums Flooring & Floor Covering 1 May 17, 2008 1:56 pm heading in the direction of floating floors in a new property for the living/kitchen level.
this level is currently carpeted and a small amount of laminate flooring in the kitchen area. my problem is i HATE those half round edges that finishes where the flooring meets the skirting board. the way to solve it is obviously remove the skirting, would the tradesman that does the floor install remove the skirtings or would i have to arrange this prior to work commencing and have re-installed pre-paint & decorate? thanks in advance. Re: lamintate flooring finish. 2May 17, 2008 7:53 pm This depends on who does the floor.
Some will take them off for you, you will have to check with the company you choose if they will or won’t remove and replace the skirting for you. The funny round edged thing is called Scotia. I agree with you, it looks awful! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: lamintate flooring finish. 4May 17, 2008 9:53 pm We had to get the 3/4 around the edge because all our architraves and door frames are concreted in! We had to remove a small amount when we moved in because our fridge wouldn't fit into the cavity in the kitchen and we ended up ripping the bottom of the wall off. Re: lamintate flooring finish. 5May 18, 2008 9:30 am FionaL We had to get the 3/4 around the edge because all our architraves and door frames are concreted in! We had to remove a small amount when we moved in because our fridge wouldn't fit into the cavity in the kitchen and we ended up ripping the bottom of the wall off. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com 4 14475 Building Standards; Getting It Right! But they didn't even leave it at one level it goes up and down along the whole front of the house 4 10950 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6218 |
