Browse Forums Flooring & Floor Covering Re: Carpet in Perth 2Feb 27, 2014 12:19 pm I know of a 60oz Solution Dyed Nylon from Quest Carpets, also Beaulieu have a 50oz SDN plush aswell. Hope this helps Re: Carpet in Perth 3Feb 27, 2014 2:20 pm My only tip with carpet is go quality. Don't fall for the cheap stuff. They all look good but the cheap wears over time. 1 16169 they can, it's a fairly standard solution when the slab isn't recessed. the falls need to be in the main floor, if it hasn't been done then you need to ask them to redo… 4 6752 Thank you. Do I use timber floorboards for stairs or do people use timber treads? Or is both the same? 6 7593 |
