Browse Forums Flooring & Floor Covering Re: Timbernate flooring 3Dec 04, 2013 5:07 pm squirrel Has anyone installed timbernate wood flooring? What are your thoughts. Specs sound impressive. If you like that product, you should also look at Timbermax. Similar idea to Timbernat yet superior due to its Multi layered ply construction rather than fibre board construction (resulting in superior dimensional stability and impressive resistance to permanent damage from water when compared to fibre board cores.) Re: Timbernate flooring 4Oct 05, 2014 6:07 pm Timbernate has 18 coats of top UV coating as compared to the 14 coats of Timbermax though. Reading the brochure of both products, they are very similar and one can only speculate that they come from the same factory in China. Timbernate being exclusive to some stores in Australia (e.g. Trevors and Homemirus) while Timbermax with Harvey Norman. Re: Timbernate flooring 5Aug 18, 2015 6:40 pm I'm installing spotted gum timbernate from Trevor's carpet First Build, Commodore Homes, Honeywood, Wandi. viewtopic.php?t=77170 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6269 Engineering timber is certainly a less fuss option, times cheaper to supply and install and better withstands humidity. 1 16006 Hi there, I'm a conplete newbie to this, but I'm looking to put a floor down in my 6x9m shed. It's currently sitting on a 100mm thick concrete perimeter (dirt floor… 0 6544 |
