Browse Forums Flooring & Floor Covering 1 Nov 02, 2013 11:27 pm Hi all, I am wondering if anyone has installed laminated floating floors. In particular the Titan Longboard 12mm. http://www.premiumfloors.com.au/laminat ... -brushbox/ My husband want to install this particular one, but I am a little hesitant because of the glossy surface. Yes it looks nice, but it will show all the scratches. If anyone has had first hand experience with this product, I would really appreciate some feedback. It looks high maintenance. Thank you in advance. Sophie Re: Need advice about Laminated floating floors 2Oct 10, 2014 9:35 am Not sure if this will apply to you now as it's a year later but great product if installed properly and careful attention needs to be put into the levelling of the slab. If the slab is not levelled prior to installation you will have a very bouncy floor and not a good result. There are many levelling agents that you can use one drawback the levers are very expensive. Thanks Simon, I guess I'm no concerned with the volume of the noise rather that dead and hollow sound and feel that is associated with floating floors. But I'm not sure… 3 6165 Thanks, that's the motivation I needed to give it a try sooner rather than one day! 4 3021 To put anything over slate you will need to put self level compound over the entire area as slate various in thickness and is very un even. To install most types of… 1 419 |
